eaccelerator installation failed
mmxp
New Member
Since eaccelerator 0.9.5 can work with Zend Optimizer. so I would like to install it on my VPS. I tried everything following the instructions at http://www.eaccelerator.net
since I have only one php installed, so I did
phpize
./configure
make
make install
eaccelerator.so path is: /usr/local/lib/php/extensions/no-debug-non-zts-20060613
so I added in php.ini above [zend]
extension="/usr/local/lib/php/extensions/no-debug-non-zts-20060613/eaccelerator.so"
eaccelerator.shm_size="16"
eaccelerator.cache_dir="/tmp/eaccelerator"
eaccelerator.enable="1"
eaccelerator.optimizer="1"
eaccelerator.check_mtime="1"
eaccelerator.debug="0"
eaccelerator.filter=""
eaccelerator.shm_max="0"
eaccelerator.shm_ttl="0"
eaccelerator.shm_prune_period="0"
eaccelerator.shm_only="0"
eaccelerator.compress="1"
eaccelerator.compress_level="9"
and I restarted Apache
mkdir /tmp/eaccelerator
chmod 0777 /tmp/eaccelerator
php -v
but it turned out that eaccelerator was not working
Any suggestions?
You CANNOT load it that way. It will never work like that.
Instead:
Set extension_dir to php.ini to /usr/local/lib/php/extensions/no-debug-non-zts-20060613/
then load it as
extension=eaccelerator.so
Instead:
then load it as
tried it, doesn't work yet :(
